cucm 6 log of ip phone startup activity
Hello Guys, where can i find the log of the Cisco ip phone activity in CUCM?? i was going through this
(https://supportforums.cisco.com/docs/DOC-33384)  but this didn't help.
Thank You!
1 ACCEPTED SOLUTION
Then you need to look at CUCM traces.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Exactly what are you looking for???
The log of what happens with a phone is either the CUCM traces, or for some events, the app log.
java
java
thanks! basically i want to view different message id of sccp so i can troubleshoot my devics better. so if something goes wrong i can easily view the log and see in which part my phone device is getting hiccups(exactly after which message id).
java
java
115
