CUCM 6 Plugins compatibility
my customer is running CUCM 6.x uses both attendant console and assistant console (IPMA) and wants to upgrade to Windows 7 64bit. does anybody know of any compatibility issue?
Thanks in advance.
Re: CUCM 6 Plugins compatibility
Legacy AC won't be tested against Windows 7 as it will be dropped in 8.X and only CUxAC will be supported. You're free to try, but it's not tested/supported.
Cisco Unified Communications Support for  Microsoft Windows 7
http://www.cisco.com/en/US/partner/prod/collateral/voicesw/ps6789/ps7046/ps7282/product_bulletin_c25-563280_ps556_Products_Bulletin.html
Product
Windows 7 32-bit Support FCS Dates
Windows 7 64-bit Support FCS Dates
Cisco  Unified Communications Manager Assistant
Version 8.5(1) FCS Q4CY10
WoW64 - Version 8.5(1),  FCS Q4CY10
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
I use the attendant console on windows 7 64 bit and it works fine. Have not tested the other.
750
