CUCM 6 TFTP Service activation
Guys,
I have just installed Cisco Callmanager 6 on vmware. My IP phones are not registering with CCM, I noticed Cisco Callmanager and TFTP services are in inactive state in System-->Service Parameters. How do I activate these services?
Many Thanks,
1 ACCEPTED SOLUTION
Re: CUCM 6 TFTP Service activation
activate the service thru CUCM serviceability, you must have the node, DLU and feature licenses if you want to start the services and register phones.
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
aha...I did not notice the Navigation tool at the right hand top corner.
Anyway, thanks for the quick reply.
671
