07-30-2008 11:32 PM - edited 03-15-2019 12:19 PM
Does anyone know if it is possible to map the CUCM 6.x field 'User ID' to the AD field 'telephoneNumber' instead of 'sAMAccountName'?
This change would speed up the login procedure for Extension Mobility users as our AD usernames are 10 characters long.
Solved! Go to Solution.
07-31-2008 07:30 AM
under system -> LDAP system you can see the attributes you can map to the user ID.
If you're already configuring this, you should have seen this as is the very first step
i believe telephonenumber is there
java
if this helps, please rate
07-31-2008 07:30 AM
java
07-31-2008 10:34 PM
Thanks! (do I feel bright now..)
