CUCM 6.x AD integration - Modify LDAP field mappings
Does anyone know if it is possible to map the CUCM 6.x field 'User ID' to the AD field 'telephoneNumber' instead of 'sAMAccountName'?
This change would speed up the login procedure for Extension Mobility users as our AD usernames are 10 characters long.
1 ACCEPTED SOLUTION
Re: CUCM 6.x AD integration - Modify LDAP field mappings
under system -> LDAP system you can see the attributes you can map to the user ID.
If you're already configuring this, you should have seen this as is the very first step
i believe telephonenumber is there
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
Thanks! (do I feel bright now..)
170
