Community Member
CUCM 6.X integration with Microsoft AD using LDAP
We are doing a CUCM 6.X integration with Microsoft AD using LDAP.Can you pls share any exact doc on this.
~Shiv
Community Member
Re: CUCM 6.X integration with Microsoft AD using LDAP
Attached you'll find a quite clear ppt on this, and here
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmcfg/b02ldsys.html
there's the CUCM Administration guide chapter on it.
HTH,
Alberto
Community Member
I am trying to do this as well.
We need to get LDAP integration working so we can setup a cell phone directory on an external server.
The cell phone numbers can be pulled from AD.
The download that you attached is for CCM 5.X
Will this also work for CUCM 6.X?
It looks very similar.
It works the same for both versions.
Community Member
Right on.
We are reviewing that documentation now and it looks like it will be very helpful.
Another question about permissions needed for CUCM LDAP Authentication?
I am thinking that any account with domain admin permissions should work for this?
Community Member
The user should have permissions to pull out users from ldap, i.e. you don't need a domain admin, a domain user in my last deployment was sufficient.
HTH,
Alberto
Community Member
Ok thanks.
We have a test script working now that will query AD and return results correctly.
181
