CUCM 6.X or 7.X
Hello. Currently on CM 4.2, unity 4.2. Making the plunge soon to either CUCM 6 or 7. Curious as to any horror stories or recommendations.
Hall of Fame Super Silver
Re: CUCM 6.X or 7.X
I would recommend going with CM 7 as it has proven to be stable, and 6.1 is going EOS very soon.
HTH,
Chris
Green
Re: CUCM 6.X or 7.X
7.X is the way to go
Hall of Fame Super Red
Re: CUCM 6.X or 7.X
Hi Pete,
Hope all is well!
You can't beat getting feedback from two experts like Chris and Gonz! +5 Points each for your great ongoing support here.
FWIW ....we have decided upon the CUCM 7.x upgrade path as well Pete :)
Cheers!
Rob
Re: CUCM 6.X or 7.X
Thanks for all the input.
I'm also assuming unity version 7 as well, correct?
Re: CUCM 6.X or 7.X
That would be my suggestion as well.
Chris
140
