CUCM 6.x trace files
Can anybody help in trying to trace the following file -
cm/trace/dbl/showtechdbstateinfo_cdr_err3829.out
Cheers,
James
Green
Re: CUCM 6.x trace files
Hi James,
I dont understand what exactly you want but to see a file use :
file view active cm/trace/dbl/showtechdbstateinfo_cdr_err3829.out
file ? is your friend
I have never collected a CCM trace from a linux CCM before, so l am trying to find out where that file is stored.
I know that you are to use the RTMT tool and then go into trace collection, but l just wondered where the above file is located??
II tried to access the file as you described above and received the following -
admin:file view activelog cm/trace/dbl/showtechdbstateinfo_cdr_err3829.out
SERVER:SEQNO REVIEW TIME ERROR
end of the file reached
Any help??
211
