CUCM 7.0.0 Upgrade
Hi All,
I can make the CUCM update from 7.0.0.0 to 7.1.3.30000-1?
If yes, I can make it just to do download of the update and aply in my server on Cisco CUCM OS Adm?
Thank you
Re: CUCM 7.0.0 Upgrade
Someone can help me in this issue?
Hall of Fame Super Red
Hi Jefferson,
Here is the supported upgrade matrix for your reference;
Table 7     Supported Cisco Unified Communications Manager Upgrades for Release 7.1(3x)
7.1(3b)SU2
7.1(3b)SU1
7.1(3b)
7.1(3a)SU1a
7.1(3a)SU1
7.1(3a)
7.1(3)
System Version
7.1.3.32900-4
7.1.3.31900-1
7.1.3.30000-1
7.1.3.21901-1
7.1.3.21900-4
7.1.3.20000-2
7.1.3.10000-11
Release Date
Feb 18 2010
Dec 15 2009
Dec 15 2009
Dec 8 2009
Dec 1 2009
Nov 4 2009
Sep 22 2009
Standard Support
Direct upgrade:
7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3)
Direct upgrade:
Direct upgrade:
7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1, 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
Direct upgrade:
Direct upgrade:
Direct upgrade:
7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a) SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 5.1(3g), 5.1(3f), 5.1(3e)1 , 5.1(3d), 5.1(3c), 5.1(3b), 5.1(3a), 5.1(3)
Direct upgrade:
Direct upgrade using DMA:
none
none
4.3(2), 4.2(3), 4.1(3)
none
none
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp43011
As you can see there is no direct path from 7.0.(0), you will need to be at 7.0(2) at least
Cheers!
Rob
To add to Rob's post and reiterate something that a number of us have said throughout the forums, don't just get to 7.0(2) and think all is clean and green.  Your target should likely be 7.1.3.32900-4 which is 7.1(3b)SU2.  That, for me, has proven to be a very stable and flexible (in terms of upgrade paths) release for 7.x.  So get to 7.0(2) with the though of immediately moving on to 7.1(3b)SU2 and you, the folks who run your system, and your company will be better off for it.  The 7.0 releases were pretty ugly from a bug perspective.  Play smart now, work a bit less later.
Hailey
Please rate helpful posts!
311
