Community Member
CUCM 7.0(1) in VMWare
I'm trying to build a lab VMWare 7.0(1) system to check out some features, its not a production system.
I've built many 5.x and 6.x VMWare systems that have always gone fine.
When I try an upgrade from 6.x to 7.0(1) it always results in a failure to reboot after the upgrade has finished with
"Kernel panic - sync failed: attempted to kill init". I've tried 3 upgrades.
I've also tried a fresh 7.0(1) build in VMWare and it complains about not having valid hardware. I have the same settings as my 6.x VMWare sessions with 2-3gb RAM and 72gb SCSI drive.
Anyone done this sucessfully?
Community Member
Re: CUCM 7.0(1) in VMWare
Did you manage to solve this ? i'm having the same problems.
Bronze
I had the same problem. Bump up the drive size higher. I might have done 80GB. I'll have to double check.
Is it an AMD machine?
I heard AMD is not supported
Community Member
I heard the same. Would be nice if they would fix this.
233
