Community Member
CUCM 7.0.1 - Sip Trunk to a Samsung PBX
Hi forum,
I need to make a sip trunk from a test CUCM 7.0.1 to our enterprise Samsung PBX (to which PSTN lines are physically connected), in order to place some test calls. Scenario:
CUCM <---SIP TRUNK---> SAMSUNG PBX
I did the following, (but all the calls fail with a fast-busy tone):
1) In Cisco Unified Serviceability, I activated the Cisco IP Voice Media Streaming App service;
2) In System > Security Profile > SIP Trunk Security Profile, I changed the Outgoing Transport Type from TCP to UDP.
3) I configured a SIP trunk that points to the Samsung PBX ip address, the rest was left to the default settings;
4) I configured a route pattern (2! - the samsung pbx extensions are 201, 202, etc.) and in the "Gateway/Route ListRequired Field" I chose the Sip trunk I did;
5) obviously all ip phone belongs to a CSS in which the partition associated to the route pattern that goes to the sip trunk is present;
I feel I'm missing something...how can I solve this?
Thank you - Kind Regards
Daniele
P.S: on the Samsung side SIP works fine and, in fact, I can place test calls from a 3CX soft phone to the Samsung, just by calling the 2XX@samsung_ip_addrress url.
Community Member
Re: CUCM 7.0.1 - Sip Trunk to a Samsung PBX
Ok, I solved the problem :-)
I was missing:
1) the MTP configuration: you have to apply a Media Resource Group List to the SIP trunk;
2) the SIP Route Pattern configuration, where you have to configure the IP address of the SIP end point (in my case the Samsung PBX) and the partition you want to route to the SIP endpoint;
Community Member
Were you able to resolve
Were you able to resolve problem
Community Member
have not been able to make
have not been able to make samsung communicate with cucm
Can you give us more information about the issue? Did you try taking SIP traces and if so, please share the same.
- Vivek
1053
