CUCM 7.0 Billing Server configuration question
When you add a new billing server to CDR Management, does it send over all entries in the CDR database or only records generated since the billing server was defined in CUCM?
  • IP Telephony
Re: CUCM 7.0 Billing Server configuration question
It starts sending from the moment you configured it onwards
java
if this helps, please rate
java
www.cisco.com/go/pdi
Is there any way to get the system to push previous data out to the billing server?
189
