CUCM 7.0 CDR
Hi All,
I am trying to find out who called certain pattern like 911 and international call. what is best report I can choose from CDR? I chose route pattern report but it is utilization and doesn't show who called to these pattern.
any suggestion would be very appreciated.
thanks
Alex
Red
Re: CUCM 7.0 CDR
You'll have to go to service parameters and set the "zero duration" flag to true. Otherwise, only the connected calls will be displayed.
Please note that set the flag to true will increase the system load significantly. It is not recommended on a heavy system.
Michael
http://htluo.blogspot.com
Re: CUCM 7.0 CDR
thanks for the reply,
atually I am not looking for calls less than 1 second. I am looking for who calls where. Like 911 and international.
any suggestion?
thanks
Alex
Bronze
Re: CUCM 7.0 CDR
Hi, as a info, I use the SQL Query to obtain this kinds of reports.
By the way I'm using a CCM 4.1(3)
All the best
David.
247
