CUCM 7.1.3 and CUCN 7.0.2 best practices for graceful shutdown for physical move
What steps should I take to gracefully shutdown and bring back up a call manager cluster?  I need to move the publisher and subscriber to a new physical location.
Everyone's tags (1)
Hall of Fame Super Red
Hi there,
For Shutdown the recommended steps would be to shut down Sub(s) 1st followed by Pub. Once you've done the shutdown on Sub wait until it's fully down before starting next box (ping -t is your friend)
From cli
utils system shutdown
This command allows you to restart the system on the same partition, restart the system on the inactive partition, or shut down the system.
Command Syntax
utils system {restart | shutdown | switch-version}
Usage Guidelines
The utils system shutdown command provides a 5-minute timeout. If the system does not shut down within 5 minutes, the command gives you the option of doing a forced shutdown.
Requirements
Command privilege level: 1
Allowed during upgrade: No
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/6_0_1/cucos/iptpappa.html#wp1051058
For startup Pub first followed by Sub(s) again wait until Pub is fully up (services etc) before
moving to next box.
Cheers!
Rob
Thanks Rob for the support that is what I understand.  Is there anything to do with the database? or other database to voice mail Unity or Cisco emergency responder?
Scott Leibold
349
