07-12-2010 12:52 PM - edited 03-15-2019 11:40 PM
I cannot seem to get my new VG-224 to register to CM. Setting the VG-224 up as SCCP- I built the gateway in CM and configured the VG-224. I can ping the IP address of the VG-224 but it does not register to CM. Can post the VG-224 config if needed.
Any thoughts or direction?
Solved! Go to Solution.
07-12-2010 03:38 PM
Take a look at this sample config (and the associated guide):
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxssccpsplmft.html#wp1056876
And this section for basic call/registration
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsbasic.html
http://www.cisco.com/en/US/docs/ios/voice/fxs/configuration/guide/fxsbasic.html#wp1010664
HTH.
Bill
07-12-2010 03:11 PM
If configuration is 100% correct (CM and VG224), you can try:
vg224(config)#no sccp
vg224(config)#sccp
vg224(config)#no stcapp
vg224(config)#stcapp
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
07-12-2010 03:38 PM
HTH.
Bill
07-13-2010 07:23 AM
Thanks for getting back to me -
Turned out that I missed the stcapp command after the command stcapp ccm-group 1
stcapp ccm-group 1
stcapp <------------missed this
So - I didn't have the VG-224 programed correctly after all. Once I entered that the Vg-224 registered right away.
Les
