CUCM 7.1.3 on MCS-7835H Suddenly Rebooted on its own
Hi all,
I've got a CUCM 7.1.3 cluster with 4 servers (1Pub and 3Subs). Suddenly one of the Subs rebooted on its own. Has anyone run into this issue ? Any ideas what might be the root cause ? or where to go about finding the root cause ?
Thanks all in advance !!
Danny
1 ACCEPTED SOLUTION
Re: CUCM 7.1.3 on MCS-7835H Suddenly Rebooted on its own
You can use RTMT tool to check the logs before your SUB rebooted. I would do also a show hardware and get the version of the firmware on the Raid controller. There are some well known Bugs with earlier versions. You can paste the output here and we can tell of it is the case or not.
Please rate helpful answer!
Hi Amine !! Thanks for your response !! Below is the show hardware output, please let me know what you find. Thanks !!
admin:show hardware
HW Platform       : 7835H
Processors        : 1
Type              : Family: Xeon
CPU Speed         : 3066
Memory            : 4096 MBytes
Object ID         : 1.3.6.1.4.1.9.1.584
OS Version        : UCOS 4.0.0.0-31
Serial Number     : EA07MKP22H
RAID Version      :
RAID Firmware Version:  2.76
RAID BIOS Version: N/A
BIOS Information  :
09/15/2004
RAID Details      :
Smart Array 5i in Slot 0
   Bus Interface: PCI
   Slot: 0
   RAID 6 (ADG) Status: Disabled
   Controller Status: OK
   Chassis Slot:
   Hardware Revision: Rev B
   Rebuild Priority: Low
   Expand Priority: Low
   Surface Scan Delay: 15 sec
   Cache Board Present: True
   Cache Status: OK
   Accelerator Ratio: 100% Read / 0% Write
   Read Cache Size: 48 MB
   Write Cache Size: 0 MB
   Total Cache Size: 48 MB
   Battery Pack Count: 0
   SATA NCQ Supported: False
   Array: A
      Interface Type: Parallel SCSI
      Unused Space: 0 MB
      Status: OK
      Logical Drive: 1
         Fault Tolerance: RAID 1+0
         Heads: 255
         Sectors Per Track: 32
         Cylinders: 35139
         Stripe Size: 128 KB
         Status: OK
         Array Accelerator: Enabled
         Unique Identifier: 600508B1001FFFFFA00CBF45EBE10007
         Disk Name: /dev/cciss/c0d0
         Mount Points: /partB 24.6 GB, / 24.6 GB, /grub 258 MB, /common 85.4 GB
      physicaldrive 2:0
         SCSI Bus: 2
         SCSI ID: 0
         Status: OK
         Drive Type: Data Drive
         Transfer Mode: Ultra 3 Wide
         Transfer Speed: 160 MB/Sec
         Rotational Speed: 15000
         Firmware Revision: HPB9
         Serial Number: 3LN7NHQT000090144TWA
         Model: COMPAQ  BF1468B26B
      physicaldrive 2:1
         SCSI Bus: 2
         SCSI ID: 1
         Status: OK
         Serial Number: 3LN7NLBK00009014NNX7
Doesn't look like there is an issue with this hardware. I would still check the logs using RTMT for any errors before the reboot. Also, this could be caused by the environment ; UPS, power issues, etc.
Thanks Amine !! I will look into the logs and check power source.
Danny
230
