10-03-2010 11:10 PM - edited 03-16-2019 01:08 AM
Hi all,
We have a CUCM 7.1.3 PUB server running on 7816 server and we are planning to to run two Subscribers on Virtual machines. Can anyone advise if it would be possible?
Thanks in advance!
James.
Solved! Go to Solution.
10-04-2010 04:57 AM
If you mean for a production environment where you would like Cisco to support your deployment, no. And there are two reasons.
We only support CUCM virtualization on 8.0(2) and above AND if you're using 7816 then you can only have ONE MORE SERVER.
7815/7816 can only be deployed up to a maximum of two servers per cluster and cannot be mixed with any other platform.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
10-04-2010 04:57 AM
java
10-04-2010 10:34 PM
Well...this is not a production environment..kind of lab setup.
Thanks for the reply!
-James.
