CUCM 7.1.3 users in different device pool can't call each other
ichehouri
Level 2
Level 2
dear all,
i have a cluster of four servers v7.1.3. Site A is having 3 servers (publisher and two subscribers) and site B is having one subscriber. i created two device pools (one for each site). and each device pool is having its CM group and MRGL. i am using the same region.
If the phones are in same Device pool they can call each other and if different device pools they can not.
regards,
Ibrahim
9 Replies 9
iptuser55
Level 6
Level 6
Obvious question but , do you use Auto Reg? The DP`s can allocate Auto Reg CSS and maybe this CSS does not contain the Partitions?
I am not using auto registration and at this stage iam not using partitions.
the phones are registered but iam not sure why is this happining. is there any thing related to media resources (note that iam using same region for device pools and thus same codec
regards,
Ibrahim
Hi Ibrahim,
When the call fails do you get a fast busy, or call can not be completed as dialed?
While the devices are in different device pools, what is the region setting between them, what codec are they defined to talk in? what are the media resources in their MRGL's?
Kunal
iam geting fast busy.
iam using same region to both device pools with codec G711.
for the MRG iam using the following:
ANN_2
ANN_CallManager1-HO
NCB HO DP
Registered with 10.65.15.22
10.70.78.111
ANN_3
ANN_10.65.15.22
NCB HO DP
10.65.15.22
ANN_4
ANN_10.65.15.21
NCB HO DP
10.65.15.21
ANN_5
ANN_10.128.60.20
NCB K10 DP
Registered with 10.128.60.20
10.128.60.20
CFB_2
CFB_CallManager1-HO
NCB HO DP
10.70.78.111
CFB_3
CFB_10.65.15.22
NCB HO DP
10.65.15.22
CFB_4
CFB_10.65.15.21
NCB HO DP
10.65.15.21
CFB_5
CFB_10.128.60.20
NCB K10 DP
10.128.60.20
MOH_2
MOH_CallManager1-HO
NCB HO DP
10.70.78.111
MOH_3
MOH_10.65.15.22
NCB HO DP
10.65.15.22
MOH_4
MOH_10.65.15.21
NCB HO DP
10.65.15.21
MOH_5
MOH_10.128.60.20
NCB K10 DP
10.128.60.20
note:
10.70.80.111 (publisher server): i am not including the ANN, MTP, MOH and CFB for any MRG for this server
10.65.15.22: first subscriber server in site A
10.65.15.21: second subscriber server in site A
10.128.60.20: subscriber server in site B
HQ MRG:
ANN_3
ANN_4
CFB_3
CFB_4
MOH_3
MOH_4
MTP_3
MTP4
K10 MRG:
ANN_3
ANN_5
CFB_3
CFB_5
MOH_3
MOH_5
MTP_3
MTP_5
The phones in Site A are using MRGL having HQ MRG as member and phones in Site B are using MRGL having K10 MRG as member
Hi Ibrahim.
Looks like a media negotiation issue..
What is the MRGL being used on the NCB HQ DP  and on the NCB K10 DP, is it the same?
Or is the MRGL being used on the device level, are the MRGL's on the phone the same?
With out the call manager trace its giong to be very hard to say why its failing..
Set the traces to detailed on all the nodes and grab a trace for the bad call.
fillow the link below to collect call manager traces:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Mention the calling, called party numbers, with the MAC address of the phones.
Kunal
Hi Kunal,
iam not putting any MRGL under DP. iam putting it under the phone settings only (phones in site A using HQ MRGL and phones in site B using K10 MRGL.
i also did a test where i put site A phone and site B phone on the same MRGL and i reset the phones but still not working.
regards,
Ibrahim Chehouri
Hi Ibrahim,
PLease collect call manager traces and post them with the right information, i il have a look why it fails.
Kunal
i do not know what happened (maybe the reseting of DP), the calls are working now.
any way thanks for the support.
regards,
Ibrahim Chehouri
Cool,
anytime!
Thanks for keeping us posted
tc
kunal
