07-13-2010 05:15 AM - edited 03-15-2019 11:41 PM
Needed to know what is the maximum number of SIP trunks supported on a CUCM 7.1.3b server and/or cluster.
Also, can the SIP trunks be incremented by port number (I know 5060 and 5061 are reserved) - for example, using the same IP address to another 3rd party SIP device, but needing additional SIP trunks to the same server/IP - can I just increment the SIP port numbers? And if so, how many trunks (Port numbers) can I support to a single IP address?
Thanks.
Solved! Go to Solution.
07-13-2010 06:52 AM
•A cluster consisting of MCS 7825 or MCS 7835 servers can support a maximum of 600 H.323 devices (gateways, trunks, and clients), digital MGCP devices, and SIP trunks.
•A cluster consisting of MCS 7845 servers can support a maximum of 2100 H.323 devices (gateways, trunks, and clients), digital MGCP devices, and SIP trunks.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/callpros.html#wp1043871
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
07-13-2010 06:52 AM
java
