CUCM 7.1.5 Backup failed after Sub IP Address change
This seems like it should be a simple configuration task I missed when changing the IP of a subscriber server. Both the Pub and other Sub backup completes successfully. Error is due to the Trace Collection Tool. Ideas?? Thanks!
Server : CUCM-03
Feature : CCM
Component : TCT
Time Completed: 2012-02-11-00-16-53
Result Code : 1
Result String : ERROR
2012/02/11 00:16: du -sckL /usr/local/cm/conf/TraceCollectionJobList.xml | grep total | awk '{print $1}'
2012/02/11 00:16: Free space on /common/drf = 66386096 KB, required space = 4 KB
2012/02/11 00:16: Ready for backup
----> BEGIN Standard Output
----> END Standard Output
----> BEGIN Standard Error
----> END Standard Error
RTMT error:
CiscoDRFFailure
Reason : DRF was unable to backup component SYSLOGAGT.Error : Incomplete Parameters
AppID : Cisco DRF Master
ClusterID :
NodeID : CCM-01
CiscoDRFFailure
ClusterID :
NodeID : CCM-01
1 REPLY
I figured out the issue. I was only allowing certain IP addresses to have access to the SFTP server for backup. I forgot to update the SFTP server with the new IP of the Sub.
So if you see this type of error when a CUCM backup fails...check your SFTP server first!!
1017
