CUCM 7.1.5 CAR Mail Parameters and Scheduler Setting
I'm going to setup a regular report from CAR, my CUCM version is 7.1.5. But I don't know what is the password I should enter here as from document it says CAR does not support SMTP authentication, detail I pasted below.
In addition, if I don't set the "Mail Parameters" in CAR and start the scheduler, where will be the report stored and how to get it? Appreciated your help, thanks!
Mail Id*
Password
Confirm Password
Mail Domain*
Mail Server Name*
  • Choose System > System Parameters > Mail Parameters.
The Mail Parameters window displays.
  • In the Mail ID field, only enter the e-mail identifier that will be used in the From field when e-mails are sent (for example, smith1@abc.com, enter smith1 in the Mail ID field.
Note : CAR does not support SMTP authentication. You must disable authentication on the SMTP mail server.
  • In the Mail Server Name field, enter the domain name for the server that runs the e-mail system (that is, abc.com from the example in Step 2).
  • To make the changes, click the Update button.
  • IP Telephony
1 ACCEPTED SOLUTION
Hi Jay,Please check the
Hi Jay,
Please check the following
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/service/5_1_3/car/car/carsycfg.html#wp1092290
Step 1 Choose System > System Parameters > Mail Parameters.
Step 2 In the Mail ID field, enter the e-mail identifier that will be used in the From field when e-mails are sent.
Step 3 In the Password field, enter the password that is used to access the server that is running the e-mail system.
Note CAR does not authenticate the user ID and password. You must disable authentication on the mail server or enter a valid user ID and password.
Step 4 In the Confirm Password field, enter the same password from Step 3 to confirm.
Step 5 In the Mail Domain field, enter the domain name for the server that is running the e-mail system.
Step 6 In the Mail Server Name field, enter the name or IP address of the server that is running the e-mail system.
Step 7 To make the changes, click the Update button.
Manish
Hi Jay,
Manish
VIP Purple
Hi Jay, In addition to what
Hi Jay,
In addition to what Manish has said[+5], you can also refer the link
https://supportforums.cisco.com/discussion/11752821/cdr-reporting
regds,
aman
75
