CUCM 7.1.5 Directory with external numbers
I've installed CUCM 7.1.5 in a test environment and I would like to know if it is possible to create a directory listing, with search function, of external numbers. It should also resolve calling in numbers to names. So it should provide the same functionality as the "directory-entry xx" command in CUCME.
Is this possible?
Thanks!
Everyone's tags (2)
Re: CUCM 7.1.5 Directory with external numbers
The Corporate Directory on CUCM doesn't function in this manner. You can program external numbers in the corporate directory or pull numbers from a custom built external application. The problem is it won't resolve number to name on inbound calls.
HTH>
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Reach Paolo, he has a script to do just  that.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
730
