07-05-2014 04:44 AM - edited 03-16-2019 11:18 PM
Dear Friends,
We have cisco CUCM 7.1.5 Pub on cisco MCS7816I4 server on which Publisher was running.Unfortunately there was hardware failure and server stopped working.
We also have one more cisco MCS7816I4 server on which subscriber is running due to the hardware failure all the phones registerd with subcriber now.
We do not have a backup of Publisher.Can we take a backup of subscriber atleast at this moment to avoid any further damage? as this is a production environment and 600 plus phones are there.Also now internal as well as external conf is stopped.
We are planning to completely change the Publisher hardware to bring pub up however my query is is it possible to copy the files from subscriber directly? or Do I have to reinstall the complete CUCM 7.1.5 software on this new server first than copy all the users and upload in BAT ,copy all route patterns device pool,PT&css gw config etc manually? one by one.?
DB replication wil happen again?
I need some expert advice to fix this problem without making it more complex any further.
Please help..
Ajith
Solved! Go to Solution.
07-09-2014 05:11 AM
Hi Ajith,
All the supported MCS servers ( HP / IBM ) are listed in the following link
http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/prod_brochure0900aecd8062a4f9.html
Yes, CUCM 7.1 will be end of support in June 2015, please check the following link
http://www.cisco.com/c/en/us/products/collateral/unified-communications/unified-communications-manager-callmanager/end_of_life_notice_c51-695269.html
It is advisable to plan an upgrade to 10.x, 8.x should be avoided as their EOL notice is also out
http://www.cisco.com/c/en/us/products/collateral/unified-communications/7800-series-media-convergence-servers/eos-eol-notice-c51-730843.html
Manish
07-05-2014 07:20 AM
Hi Ajith,
You need to open a TAC for it if you do not have CUCM backup, TAC engineer can push/restore the backup from subscriber to publisher, I had faced the same issue with CUCM 8.0 publisher, that time TAC engineer helped me on that.
Suresh
07-05-2014 10:21 AM
Dear Suresh,
I think as per my understanding on MCS server cucm 7X and below version its not possible but on 8 and above onwards its possible I am bit confused on that.
And is it only possible from TAC to push the configuratrion? there is no doc availabe?
and also I have checked all the parameters but conference is not happening is it beacuse the conf bridge config is now no longer registerd with pub?
07-06-2014 01:22 AM
My current Server is having below configurationa
Cisco MCS 7816-I4 Configuration
Component Value
Product part number MCS7816I4-K9-CMC2
Preload Cisco Unified Communications Manager 7.1
OS included Yes
Processor Single Intel Dual Core Xeon E8400 3.0-GHz 6M L2
Memory 2-GB (two 1-GB) PC2-5300 Error Checking and Correction (ECC) double data rate 2 (DDR2)
Hard disks One 250-GB Serial Advanced Technology Attachment (SATA) 3.5-in. cold-swap drive
Remote management IBM Remote Supervisor Adapter (RSA) II Slimline supported, but not included
Due to hardware Failure PUB is down on this.
We have an addiotional Hardware with us on which We are planning to install publisher now I am not able to find E5620 instead E5630 is available on the IBM data sheet will this below hardware ould support?
MAnufacturer IBM
Model Bladecenter HS22-(7870IZS)
Processor Intel (R) Xenon (R) CPU E5620 @2.40GHZ 2.39GHZ
RAM 8 GB
System type 64 bit operating system
07-07-2014 08:22 AM
8.6(1) added the functionality to do the restore from a subscriber node without root/TAC access: http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/116946-technote-product-00.html
Most TAC engineers with root access will not attempt the 7.x subscriber->publisher restore for you as there's no guarantee it will work and is a difficult process. Usually it's only even attempted for very, very large customers.
07-08-2014 04:24 AM
Thx Brian for the update on this !!
So do you think best option would be to build a offline setup (pub) on a new server and thn copy all the information and combine it with sub ?
We are planning to do this as I belive there wont be any other options available
07-08-2014 07:11 AM
There's not really much possible that I can think of. You can't run BAT to export any data since you need the publisher for that. You can't add that subscriber to a new publisher as the new publisher will just overwrite all the data. You'll have to rebuild both nodes to get a fully functioning cluster. You're looking at building it from scratch or possibly manually copying things over from looking at the subscriber's web pages/SQL Database.
07-09-2014 05:04 AM
Dear Brian,
Thanks for your help !!
Could you sugest any equivalent server which is ok to run CUCM 7.1.5 in IBM model.
Or what would be a minimum configuration required to run CUCM 7.1.5 because The current MCS server i guess will be end of sell
Is it true that cisco gonna stop support for cucm 7 version from next year? and will it be a wise decision to put the same version or should we go ahead with an upgrade to 8 and above?
07-09-2014 05:11 AM
Hi Ajith,
Manish
07-06-2014 05:11 AM
Hi Ajith,
As mentioned bu Suresh (+5) TAC may help you in this scenario, however there is no guarantee that the entire database will be restored even through root access. You might end up using BAT to export / import data. Just wanted to check if you have tried running the recovery disk to bring up the Publisher, or has it completely stopped booting up.
Manish
07-06-2014 07:31 AM
Hello Manish,
Wel This is one of our old customer and I think they never had taken any backup or niether they have any recovery disc.
We only have CUCM7.1 disc do you think will that disc help us in recovery?
since there is complete hardware failure (MCS server) we are now planning to move to a different Server
Could you just help me with below query with respect to compatibilty
Component Value
OS included Yes
We have arranged another IBM server on which We are planning to install publisher now I am not able to find E5620 instead E5630 is available on the IBM data sheet will this below hardware would support? cucm 7.1.5
MAnufacturer IBM
RAM 8 GB
Also how we can start the conference ? facility again is it only posible after we make the pub up?
07-06-2014 08:37 AM
Hi Ajith,
As much as I know, we can not start the conference if publisher is down because all such administrative task has been disabled now.
If you do not have recovery disc, then you can download from below link.
http://software.cisco.com/download/release.html?mdfid=282421166&softwareid=282074294&os=&release=7.1%285b%29&relind=AVAILABLE&rellifecycle=&reltype=latest&i=!pp
For this server, I am also not much sure as this is not customized (OS) server from Cisco. If you do not have any challenge then why don't you start installing CUCM on it and then you will see.
I hope you already done RMA for faulty server, you can push Cisco to get it early as possible.
Suresh
07-06-2014 08:43 AM
You can download the recovery iso from cisco.com and burn it on a disk and boot up from that disk to run a file system check / correction.
http://software.cisco.com/download/release.html?mdfid=282421166&flowid=45895&softwareid=282074294&release=7.1%285b%29&relind=AVAILABLE&rellifecycle=&reltype=latest
It is likely that the conference bridge that the phones are trying to use is unregistered because of Pub being down, can you check the MRGL of the IP phones which you are trying to get conferenced and see if it has the conference bridge (un)registered with Pub in the MRG at a higher priority.
Manish
07-06-2014 09:03 AM
Yes manish
Its status is unknown and its no longer registered with pub.
However is it not possible to shift this group on sub? as we have primary as pub and we also have secondary at sub however currently they are registerd on sub and it belongs to a different device pool
07-06-2014 09:11 AM
Dear manish,
could you just help me with the sever compatiblity matrix? which i have posted is the IBM server which we have is compatible? to install pub? as processor seems less than the current MCS
