CUCM 7.1 and CDR through ODBC
Hello All,
I have cucm 7.1 and want to use IBM client and connect through ODBC. Is this possible? We have similar config for UCCX and want to explore CDR using same method.
Any guidance is appreciated.
Kadambari
Everyone's tags (3)
1 REPLY
Super Bronze
There's no direct DB access.
Best idea would be to set up a database server which also has an SFTP or FTP server running. You can then add this server as a 'billing server' to CUCM, and put together some code (or use the tools that come with the database) to import the files that CUCM exports.
Aaron
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
387
