cucm 7.1 Backup failed at reporter and ccmdb
I am in the midst of reinstalling my ccm 7.1 due to some "journal...etc" problem that appears on the console, my users are not be able to logon when this problem appears.
However my backup doesnt seems to work. I am using a freeFTPd as my sftp server. my backup constantly failed at reporter and ccmdb. I attached the 2 reports for your analysis. Also I find out that, whenever I run the CDR(actually we didn't make use of this) like generating a report, it failed with a rather blank screen telling me to look for administrator.
Given that the backup failed at reporter, and ccmdb where a single entry in the backup log shows failure, is it advisable for me to perform a fresh reinstall of the cucm, and restore from the backup?
urgently need your advice,
paul
Everyone's tags (6)
Hall of Fame Super Red
Re: cucm 7.1 Backup failed at reporter and ccmdb
Hi Paul,
Have a look at this section of the attached doc  (due this error from your logs -
CCMDB Backup failed, unable to tar data to master agent)
DRS Hangs During CCMDB Backup
http://www.cisco.com/image/gif/paws/111796/cucm_drf.pdf
Cheers!
Rob
"Everything is broken" - Bob Dylan
Hi Rob,
Thanks for the reply. I go through the portion under DRS Hangs during CCMDB backup, following the steps, and restarting the DRF before i attempted another backup, but failed.
1) there is not any directory that match the document.
admin:file list activelog /cm/cdr_repository/destination/*
no such file or directory can be found
admin:file delete activelog /cm/cdr_repository/preserve/* noconfirm
files: found = 0, deleted = 0
admin:file delete activelog /cm/cdr_repository/car/* noconfirm
admin:
2) both backup logs show "Cannot stat: Input/output error"
reporter
tar: /var/log/active/cm/report/rtmtreporter/AlertRep/AlertRep_05_16_2011.pdf: Cannot stat: Input/output error
tar: /var/log/active/cm/report/rtmtreporter/AlertRep/AlertRep_05_13_2011.pdf: Cannot stat: Input/output error
ccmdb
/bin/tar: /usr/local/thirdparty/jakarta-tomcat/webapps/carreports/reports/pregenerated/individualbillsummary/Mdarrenting20110301.pdf: Cannot stat: Input/output error
can this be file corruption, if based on the log those above are the only errors, is it trivial? for the reporter, can i ignore it? and for ccmdb, is it possible to perform certain recovery later on the file, is there a way for me to extract the same file and overwrite it after i perform a fresh install?
regards,
Paul
Hi Paul,
I wouldn't want to mess around with DRS (especially ccmdb). I'm a pretty paranoid
person when it comes to backups, so if it were me I would go ahead and open a TAC case on this one
Cheers!
Rob
Hi Rob,
Thanks for your advice. I log a case with TAC. let's see how we progress from there.
regards,
Paul
1561
