CUCM 7.1 Call Forward All - Problems
harris.h
Hi we have recently upgraded to CUCM 7.1 from 4.1, we are having intermittent problems with call forward all,
eg. we have fwd all on 2491 to 8060, sometimes 2491 will ring, but most tests will indeed forward to 2491??
Have also been to site and witnessed missed calls on the device, even though the FWD ALL is on.
Any ideas  would be appreciated.
The devices and lines, all have the same CSS and Partitions.
Cheers
Rich
Rob Huffman
Hey Rich,
Have you checked the CFWDALL CSS. In 4.x the CFWDALL CSS could
be left at but in newer versions of CUCM this CSS must be set.
Cheers!
Rob
Hi Rob and thanks for the reply,
Have assigned CSS to FWDALL, as I said sometimes the FWDALL works, sometimes not so is a nightmare to try
and solve.
Failed to say, it is only happening on 7962 phones SCCP42.9-0-3S.
Its almost like CUCM is only sometimes checking it DB before signalling the phone??
Cheers
Rich
Run a report from the Cisco Unified Reporting Tool for Database Status.  Make sure that everything is ok in there.  It almost sounds like some servers know about the forwarding and some might not, depending on which servers receives the call setup.  Another thought might be that change notification is broken on certain nodes, check "show tech notify" from the command line of each server, the CCM service should show the same number for the H and T columns.
