CUCM 7.1 - Customized Directory
In CUCME you can create an XML file and use it for Local Speed Dial. How do I acheive this in CUCM 7.1? I have a customer that wants local Speed dials common to all users in a department. Can I use the same XML files I have for CUCME, How do I get it to appear on the phone?
Re: CUCM 7.1 - Customized Directory
There is no custom directory in CUCM.   You will have to build a custom XML file and point it to a web server that has the directory you want to use.   If its common "speed dials" you can simply add this into the corporate directory.  I have done this.
Or if they are really speed dials, you can use translations.
P.Holey have you been able to complete this?
I have setup IIS and included a XML file, but I get a Parse Error.
  This is my Directory Title
  Give Me A Prompt
    Neal Haas
    123456
What is the correct XML file, or is there anything else that I need?
Super Bronze
Hi Neal
Your XML is a bit to cock - it's valid in XML terms, but not valid in Cisco XML API terms.
A correct directory object would be:
  Give Me A Prompt
    Neal Haas
    123456
1) The extra bits I've removed (, ) are different XML objects completely. You can't mix them.
2) You had a lower case P on 'Prompt' - the phones are very sensitive to things like that.
More info:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/all_models/xsi/5_1/english/programming/guide/ip5_1ch2.html#wp1033491
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks, Helped alot. By no means am I an XML expert.
Now I just need to find: pull phone info into .NET
Super Bronze
I guess you mean phone number info?
And where from?
Aaron
Yes phone number (or MAC), when a user goes into a Service, I want to provide the user
information based off of there phone number.
Neal
this  would be the solution for my case?
https://supportforums.cisco.com/message/3137563#3137563
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
916
