04-01-2010 08:34 AM - edited 03-15-2019 10:04 PM
We have recently upgraded our phone system from CM 4.2(3) to 7.1(3a). The upgraded system is working well, but users have found that when they reboot their phones or login or out of Extension Mobility (and therefore reset the phones), an error message briefly flashes up on their phone's screens saying "File Not Found - English (United Kingdom)".
I have found that the easy fix is to change the User Locale in the user's profile from English,British (United Kingdom) to English (United States).
I would like to be able to set the profiles to the correct UK locale however.
Can anyone advise how I can fix the problem?
Many thanks,
Paul
Solved! Go to Solution.
04-01-2010 08:40 AM
You need to download the GB locale from Cisco.com for your version of CCM.
You then need to install it on all nodes in the cluster, starting with the publisher.
Aaron
Please rate helpful posts...
04-01-2010 08:40 AM
Aaron
