CUCM 7.1 Report of phones that are currently forwarded
Mike Bullough
Is there a way or report for finding phones that are forwar
ded to another extension?
mightyking
Level 6
Level 6
You can use Attendant Console application to see all forwarded extensions.
MK
No reporting on this, you would need to run qrys against the numplan table to get the info
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
