CUCM 7.1 route pattern for USA fax numbers
We have a Sydney IP Telephony cluster that is currently have issues sending fax to the USA.
Here is our setup IP Telephony setup
To call international, we use 0011 (country code) (city code) (local number).
In CUCM, we have a route pattern of:
840XXXX.!
local partition
Route List points to the RL -> RG -> local Voice H323 Gateway
Called Party Transformations
Discard Digits = predot
Prefix Digits (outgoing calls) = 12345
In local Voice Gateway we have the following dial-peers setup:
dial-peer voice 1 voip
description Fax Outgoing
preference 1
voice-class codec 1
voice-class h323 1
session target ipv4:X.X.X.X
incoming called-number 12345.
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol t38 nse force ls-redundancy 0 hs-redundancy 0 fallback cisco
ip qos dscp cs3 signaling
no vad
dial-peer voice 2 voip
preference 2
voice-class codec 1
voice-class h323 1
fax rate 14400
fax nsf 000000
no vad
dial-peer voice 10 pots
description FAX OUTGOING
preference 1
destination-pattern 12345T
port 0/0/0:15
So far local, national and International works except fax to USA. Fax numbers in the USA are 11 digits long. I have debug ISDN q931 and debug voice ccapi inout on and I do not get any debugging activities on the VG when sending fax to any USA fax numbers. The USA fax number definitely works, by calling the number from a phone I hear the fax tone pick up.
Is there a limitation in CUCM that it only allows to route outgoing voice traffic on specific number of digits? Route pattern above=7 digits + international call=4 digits + the destination number=11 digits total 22 digits.
For example, 8409999=internal billing ID, 0011=Sydney International, 1=USA country code, 404=state code, 5389551=local number (not a real number)
Prefix Digits 12345 is use to identify that this is a outgoing fax call and a special rate for billing is applied.
840XXXX is use to identify the user so that we know who to bill the outgoing fax.
202
