CUCM 7.1 User Web Page not working
I am having an issue that when I go to the CCMUser webpage on our 7.1 server, I receive the login page but after entering my credentials, the page says loading but it never actually completes the process.  CCMAdmin works fine and I have stopped & restarted the Cisco Tomcat service.
Any ideas?
Nathan Richie
Re: CUCM 7.1 User Web Page not working
Have you added the user to the Standard CCM End Users group?
If yes then are you using a supported browser? - try IE 6 or later.
Also, is this LDAP integrated or using the built-in informix user DB?
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
231
