CUCM 7 CDR question
david-lima
Level 4
Level 4
Hi guys, I'm running CUCM 7.0, Is there a way to obtain a specific cdr report from CLI (calling and called party number, timestamp, etc). Please share the script if you have one.
Thanks a lot
David
Jaime Valencia
Using the run SQL command, i'll assume you already know SQL so a simple example of all 911 calls is
run sql select * from car:tbl_billing_data where originalcalledpartynumber='911'
Refer to CDR documentation for a list of all fields and what's their content.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Java, thanks a lot for your answer, just one question, where I an find the data dictionary of this tables.
Thanks again
David
Hi Java, just one more question, I have a SQL query, Is there a way to export the results from CLI admin??
Thanks gain
David
Hi Java, sorry fot this one, I run the sql: run sql select authorizationcodevalue from car:tbl_billing_data where originalcalledpartynumber='3225'
But the value shows me as NULL, Do I'm missing something in the query?
Thanks again
David
