CUCM 7 - DHCP questions
Hi all,
we switched from CCM 4 to CUCM 7 and I got 2 problems with DHCP
-is there a chance to check ip addresses which CUCM allready assigned? Like it was possible on CCM4
-Do you know the reason why DHCP assigns IP addresses from the end of the pool, not from the beggining? Or do you know how to change this behaviour?
Thanks in advance
  • IP Telephony
1 REPLY
Re: CUCM 7 - DHCP questions
there is no interface to check assigned IPs, i believe there is already an enhancement request on that.
unfortunately, you only get to configure the pool thru the GUI, but not the options on how it should work
java
if this helps, please rate
java
www.cisco.com/go/pdi
341
