CUCM 7 Export "License File Upload"
robray_sc
Level 4
Level 4
Is there a way to export all my license files from CM 7.1(3). I need to reconcile all the license files but looking for an easier way than looking at each file file under the "License File Upload" section.  I need to verify the PAK key inside each license file.
5 Replies 5
David Hailey
My lab systems only have the standard demo licenses loaded; however, you could try to retrieve the files via CLI using SFTP.  Login to the CLI as the admin and check out the command "file get install".  First you should take a look to see if the files are actually in that directory location (should be).  That command is "file show license *" and should show you all the license files by name.
Hailey
Please rate helpful posts!
Erick Bergquist
Level 6
Level 6
They are part of the DRS backup files, offhand I do not know which TAR file they are in as it's been awhile since I had to dig one out of one. I believe it may be one of the platform tar files part of the DRS backup.
Or, the following commands at the CLI (SSH) (if you have fix for CSCsw17906 in your version)
file list license
file view license
file get license
DrEAmlessoD
I know this is late, but hopefully it helps others.  The DRS path is:
XXXXXXX_CCM_PLATFORM.tar\\usr\local\cm\conf\licfiles
thanks DrEAmlessoD!
on ELM a new CLI commands for Release 9.1(2)
admin:license file get
Would you like to proceed [y/n]? Number of files: 37
Total size in Bytes: 336818
Total size in Kbytes: 328.92383
y
SFTP server IP: x.x.x.x
SFTP server port [Default = 22]:
User ID: x.x.x.x
Password: ******
Download directory: /
Connecting to remote server: x.x.x.x
The authenticity of host 'x.x.x.x (x.x.x.x)' can't be established.
RSA key fingerprint is x:x:x:x:x:x:x:.
Are you sure you want to continue connecting (yes/no)? yes
Sending to remote server: x.x.x.x
Transfer complete
admin:
