CUCM 7 (HO) Site and VG(Remote Office) FXO ringing even at off-hook
I have 2 sites involved in this case. The CM is in the HO . I have issues in the VG in the RO. All the phoned in the RO is getting register with the CM in HO. All the route patterns are mentioned in the CM in HO. When I make a PSTN call , the dialing is made though the VG in RO according the Route Pattern In CM.
The problem which I face is that i have 4 analog lines . All the call gets forwarded to the Reception Number as in the configuration below.Whats happening is like when a call comes from a PSTN line the number 4400 will ring. When I pick the call there is no indication on audio. But the person who called though the pSTN still have the phone ringing continuosly. It seems like when I off-hook the phone then FXO is not getting the proper signal to send to the Serivce Provider.
I seek expert opnion on this issue..............................
I
trunk group  analog
voice-card 0
dspfarm
dsp services dspfarm
voice translation-rule 9
rule 1 /^\(\)/ /9\1/
voice translation-profile ADD9
translate calling 9
interface FastEthernet0/0
description -----Connected to Edge Switch-----
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.1.9 255.255.255.0
ip directed-broadcast
ip virtual-reassembly
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 192.168.3.9 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.3.9
interface Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.1
voice-port 0/0/0
trunk-group analog 1
translation-profile incoming ADD9
supervisory disconnect dualtone mid-call
input gain 7
cptone AE
timeouts call-disconnect 5
connection plar opx 4400
caller-id enable
voice-port 0/0/1
trunk-group analog 2
input gain 7
cptone CH
impedance complex2
caller-id enable
voice-port 0/0/2
trunk-group analog 3
input gain 7
cptone CH
shutdown
impedance complex2
caller-id enable
voice-port 0/0/3
trunk-group analog 4
input gain 7
cptone CH
shutdown
impedance complex2
caller-id enable
dial-peer voice 12 pots
trunkgroup analog
description --- Outgoing Local Calls ---
preference 5
destination-pattern 9[2-8]......
dial-peer voice 20 pots
trunkgroup analog
description --- National Calls ---
preference 10
destination-pattern 9[0][2346789].......
dial-peer voice 30 pots
trunkgroup analog
description --- Mobile Calls ---
preference 10
destination-pattern 9[0][5][0,5,6].......
dial-peer voice 40 pots
trunkgroup analog
description --- ISD Calls ---
preference 10
destination-pattern 9[0][0]..T
dial-peer voice 60 pots
trunkgroup analog
description --- Service Number ---
preference 5
destination-pattern 9[19]..
dial-peer voice 70 voip
destination-pattern 4...
session target ipv4:172.16.3.10
gateway
timer receive-rtp 1200
1 REPLY
Bronze
Re: CUCM 7 (HO) Site and VG(Remote Office) FXO ringing even at o
It sounds like the answer supervision isn't working.Have you tried Answer supervision with battery reversal or tones?
Mark
273
