08-23-2010 08:12 AM - edited 03-16-2019 12:25 AM
Hi all,
I did installation of 2 CUCM 7.1.5 today, and licensing on publisher went OK, but for somereason subscriber is not getting the license.
Here is the output from CLI command from the subscriber:
admin:file list install *
2010-08-23 17:03:35,008 INFO [ClassExecutionThread] cli.CliSettings - VMware = false
<dir> hssi_errors
Can somebody help me please?
Thanks in advance.
Solved! Go to Solution.
08-24-2010 06:08 AM
If you have the serial number of the server you may be able to use that. You can open a case by phone too if you call your local number below:
http://www.cisco.com/warp/public/687/Directory/DirTAC.shtml
--Matt
08-23-2010 08:20 AM
You install ALL the licenses in the licensing server which is usually the PUB.
If you ordered any license with a MAC other than the one from the licensing server you need to reach licensing (licensing@cisco.com) so they can rehost them.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
08-23-2010 08:32 AM
When i sent Product Aktivation Key I did one with Publisher's MAC address and one with Subscriber's MAC address. Are you saying that both licences should be activeted with PUB's MAC?
Thank you,
08-23-2010 08:34 AM
Yes, that's correct
java
08-24-2010 12:27 AM
One more question,
What if the publisher fail, how the licences will be known by subscriber when all of them are attached to the Publisher's MAC address?
Thanks for the help.
08-24-2010 12:33 AM
The licenses are installed on the publisher, and changes can only be made on the publisher; the licenses are used when you activate a CCM service or add a phone. If your publisher is gone, you can't make changes until you replace the publisher and rebuild from backup.
When that happens you would send your license files to the TAC LIcensing team who would reassign the licenses to your new publisher's MAC address.
Aaron
Please rate helpful posts...
08-24-2010 05:53 AM
I sent an email to licensing@cisco.com but so far nobody hasn't answered me. Does this process usually takes long time or I'm knocking on a wrong door?
08-24-2010 06:00 AM
They're often quiet quick, but sometimes not.
I generally go to the TAC Support Request tool and raise a case there, picking the 'Licensing' sub category for whatever product it is. I've no doubt it goes to the same team, but like to have the TAC case number to make chasing progress easier.
Aaron
08-24-2010 06:06 AM
To open a case it is requiring Service Contract number, which for now I don't have it.
Any other workaround?
08-24-2010 06:08 AM
--Matt
