CUCM 7 SIP Trunk Logs
I've got myself a CUCM 7 lab and I'm trying to connect to a SIP Trunk provided by Link2Voip.
I've setup the paramaters for the trunk, changed the security profile for digest authentication, and created a SIP Realm, however when I dial out I'm getting fast busy tones.
Obviously something isnt configured correctly, and I'd like to know where I can see the authentication logs so I can see why its not working.
Does anyone know where I would look?
Re: CUCM 7 SIP Trunk Logs
I would follow this guide to get traces:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
You can turn everything off except for the SIP options if you just want to see the SIP messaging.
hth,
nick
Just in case you haven't seen this, Jeremy - The current strong recommendation is to use CUBE to terminate the SIP trunk for a variety of reasons. See Christina's recent post below where she outlines a number of them.
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40^1%40%40.2cd42237/5#selected_message
Michael.
And I forgot this tool, which is what you should use to decode the traces once you get them downloaded. This a tool that TAC uses as well to look at complicated CUCM traces:
http://www.employees.org/~tiryaki/tc/
hth,
nick
1288
