CUCM 7 unified Serviceability issues
Hi All
I sure could use some help...
Just finished installing the second CUCM7 as a subscriber, all went ok. However when i try yo go to the Cisco Unified Serviceability it always comes up with
HTTP Status 404 - /ccmservice/
type Status report
message /ccmservice/
description The requested resource (/ccmservice/) is not available.
Apache Tomcat/5.5.27
Any help on this will be appreciated
Okechi
Bronze
Re: CUCM 7 unified Serviceability issues
Can you access any web pages from the subscriber eg administrator , os etc?
mark
Hi Mak,
Yes I can access every other link---- cm administration, disaster recovery, OS administration.  execpt serviceability
ta
Okechi
VIP Super Bronze
This is unlikely but perhaps that Tomcat application failed to start. You can check this through the OS CLI using SSH:
admin:utils service list
Requesting service status, please wait...
...output truncated...
Cisco CallManager Serviceability[STARTED]
Cisco CallManager Serviceability RTMT[STARTED]
If either of those show STOPPED, you can try starting them with utils service start
Checked the services all started..
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STARTED]
Cisco CAR Scheduler[STARTED]
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CDR Agent[STARTED]
Cisco CDR Repository Manager[STARTED]
Cisco CallManager Admin[STARTED]
Cisco CallManager Cisco IP Phone Services[STARTED]
Cisco CallManager Personal Directory[STARTED]
Hi Friends
I am also facing the same issue...
Kindly let me know if you find a solution..
Can you run 'utils diagnose test' on SSH session to the Sub, and check if all the tomcat checks pass ?
I would also try restarting tomcat (utils service restart Cisco Tomcat) on the Sub, wait for Cisco Tomcat to start back up, and check the serviceability page again.
- Sriram
Please rate helpful posts !
2374
