Community Member
CUCM 7.x - Does it run on 64 bit or 32 bit Linux?
Does CUCM 7.x run on 64-bit or 32-bit Linux?
Can it run on both? If so, which would be the more common in deployments: 32-bit or 64-bit?
Thank you!
David
2 ACCEPTED SOLUTIONS
Re: CUCM 7.x - Does it run on 64 bit or 32 bit Linux?
I believe it's only 32bit version, as far as I remember you don't have any option to choose Linux version during installation.
Even when you look at MCS server for CUCM there is no information about 64bit parts.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/product_data_sheet0900aecd80572766.html
Hi David,
I'm sure that is 32-bit Linux version. This linux version for CUCM is based on Red Hat Enterprise linux.
If you found this post helpful,please rate it.
Hi David,
Community Member
Thank you very much folks, this answered my question.
1092
