Community Member
CUCM 7.x Inter-Trunk Configuration
Where can I find the documentation in regards to setting up an Inter-Trunk connection between two Call Managers? Both running 7.x.
     Thanks.....
1 REPLY
Re: CUCM 7.x Inter-Trunk Configuration
Trunk Configuration
OR, go to the CUCM page and use Help -> For this page
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
177
