CUCM 7.x SCCP keep alive trigger
Anyone know where the service paramter is to adjust for the keep alive parameter?   I need to turn it up a little because of a lousy network. Phones keep coming unregistered.
Re: CUCM 7.x SCCP keep alive trigger
It's a CCM service parameter, under Clusterwide Parameters (Device - General)
Station and Backup Server KeepAlive Interval
Station KeepAlive Interval
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thanks Java!  You the man.
Its related to the 797X firmware issue im having.   I upgraded firmware to the latest and the phones will not register remotely.  But if I back them down a couple versions, they work fine.  However, local phones to the CUCM work fine with the latest firmware.     I had a TAC case open, but we couldnt figure it out and though it was a bug in the new firmware for the 797x phones.  But I have a deployment coming up and no fix is in sight yet that I have seen.  Thought maybe this would be a good test for a workaround
1608
