cucm 7.x web page cannot be displayed
HI ,
      I had installed a CUCM 7.01 version in VM Ware worstation 10 , the installation was finished successfully . I can ping the server & i can access to the CLI .but the problem when i want to open the GUI .https://x.x.x.x:8443/ccmadmin/  the web page can not be displayed  .
Can you help me please to resolve this issue .
Login through CLI run this command and let me know what it showing next to call manager admin.
admin:utils service list
Cisco CallManager Admin[............]
Rate all the helpful post.
Manish
Thanks  manish for you reply
please find in attached file the show of the command utils service list .
Re: cucm 7.x web page cannot be displayed
Run this command.
admin:utils service start Service Manager    and then post uti service list
Rate all helpful post.
       command running successfully but  problem still the same , i want to tell you somthing ,i think is useful to help us . sometime i can access to the GUI and i can browse into the grafical interface for an delay 2 or 3 min ,after that the web page disappear and i can't access to it anymore . i don't know the problem is in my pc or the CUCM .
Thanks again manish for your help
VIP Purple
which browser u are using?
try changing the browser.
regds,
aman
CUCM 7 will not work on chrome try opening it in Firefox mozilla or IE.
Manish
It is the same problem with all browsers .Knowing that the Firewall disabled ,Antivirus Disanstalled .
web page disappear and i can't access to it anymore- what do you mean by that,  is it you lost connection to cucm? did you checked pinging call manager ip at that time ? getting tomcat error ? db error ?
Did you given enough space while installing cucm on vmware (ideally its would be around 80 GB)  and have set enough memory ?
Manish
VIP Purple
Hi ,
virtualisation is supported from CUCM version 8.0(2) or later.
regds,
aman
     when the web page disappear , i checked the ping is OK . While installing cucm on vmware i give the hdd an space of ( 40 GB) and the memory (2GB) ,this is the prerequis requested by vmware .
I would recommend reinstalling call manger 7 with a space of 80 GB or higher , because I have seen issues with space less than 80 GB.
Aman-  cucm 7 supports vmware if its installed properly. - check this link. -http://blog.chackraview.net/2009/12/25/installing-cisco-ucm-7-x-in-vmware/
Manish
I will try reinstalling call manager 7 .
Thanks manish for your help.
No, your statement is wrong, as Aman said, we do not support CUCM on virtualization on anything below 8.0(2), and only if you have ESXi 4.0+, anything below that, and any other virtualization SW, is not supported and you can get any sort of errors like what you're seeing.
CUCM is fine, problem is what you're trying to do with it.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
I think the problem in the VM ware configuration (HDD 40 GB) - (RAM 2GB) , otherwise i think  everything is ok .
Hi Zakariaa,
Please try with below link and see if it's help you out
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800e1691.shtml
Nishant Savalia
Regards, Nishant Savalia
Hi Nishant ,
      Sometime i can access to the GUI and i can browse into the grafical  interface for an delay 2 or 3 min ,after that the web page disappear and  i can't access to it anymore as the picture bellow :
Zakaria AZZOUZ
Give it a shot bouncing tomcat... service in charge of the webpage
admin: 'utils service restart Cisco Tomcat'
Case sensitive...
Please Kudos/rate if this help!
   I think my problem is with service Cisco Tomcat , When i restarted the service i can manage GUI for an delay of 2 min ( While the service is running ) . i don't know what is the problem exactly with that service :why it is become not activated all alone .
Hi Zakariaa,
As pointed out initially in the post cucm version 7.x is not supported on vmware. If you are running it in the lab then the only option is to provide sufficient Disk and RAM. Also, as you already have 7.0 running it would not be a bad idea to upgrade it to version 7.1.5 ( could be a step upgrade ) as the lower versions of 7.0.x and 7.1.x have numerous Tomcat related bugs.
Manish
Zakariaa,
Sorry I was away. Lets get to the root of this if you like.
Try this....
'Utils service restart Cisco Tomcat'
Let it run completly, it probably will crash your service... as soon its done trying to bring it up.. run...
'utils core active list'
If you find a core with a time Stamp of few minutes before... (running the reset), you must RUN
Utils core active analize
If you get mi this output I can look in to it, please make SURE your putty or SSH client has enought buffer, this output can be big.
Cheers
889
