CUCM 8.0 + 3945 PVDM3
Hello all,
I have some weird problems, I want to use MGCP to control a bunch of FXO ports that my voice gateway (3945) has.
This router has a PVDM3-128 DSP installed (from factory), 4 VIC2-4FXO, 4 EVM-HD-8FXS/DID, 8 EM-HDA-6FXO, 4 VIC2-4FXO, 4 SM-NM-ADPTR.
All that info i got it from a show diag and show inventory.
My problem is that when i try to configure my voice-ports .... the possible options i have are:
voice-ports <1-3> / 0 / <0-21> !!!!!!!!!!!!!!!!!
So when i configure my gateway at CUCM, the ports dont match!, so the configuration never gets downloaded!
I need some urgent help please!!!!
if you need any show outputs please tell me!!
POST:
I went ahead and did a show ver....and found something REAALLLYYYY WEIRD!!
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 985088K/63488K bytes of memory.
Processor board ID FTX1435AKH6
3 Gigabit Ethernet interfaces
1 Virtual Private Network (VPN) Module
64 Voice FXO interfaces <--------------
32 Voice FXS interfaces <------------------
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
why does it add all the FXO ports??? how do i know which one im configuring????
Hall of Fame Super Silver
Re: CUCM 8.0 + 3945 PVDM3
Can you please provide "show diag" from your router?
Chris
Hall of Fame Super Gold
Based on your description, the interface count in show version is correct.
I think that even before the problem you have identified, controlling this kind of gateway with MGCP is not a good idea.
You will loose CLID, the ability of routing on called number, or running tcl/ivr scripts and more.
Using H.323 or SIP, with trunk groups, will be a much easier and robust configuration.
Also, you will find thta managing a large number of FXOs is a nightmare. It is imperative for good results, to use PRI for so many lines.
394
