Community Member
Cucm 8.0.3a - IP Phone Services Not Available
Im building a new 2 server cluster, this is not in prod yet. I have enbled EM and Change EM Password.
It was working at one point, I am unable to assign any other services besides intercom. Extension Mobility and Change EM Password do not show up on the menu in PHONE configuration mode
They are enabled under serviceability
If I go into phone services they are there.
Change EM Password
http://10.x.x.x/:8080/changecredential/ChangeCredentialServlet?device=#DEVICENAME#
service category is XML Service
Enable is checked off
Same goes for Extension Mobility
http://10.x.x.x:8080/emapp/EMAppServlet?device=#DEVICENAME#
I have enterprise services configured to point to non dns http://10.x.x.x links
Can someone point me in the right direction?
2 ACCEPTED SOLUTIONS
Re: Cucm 8.0.3a - IP Phone Services Not Available
Did you checked the enterprise subscription option for any of the other services you've created so far?
Any service with the enterprise subscription does not need to be subscribed in the phone and won't show up when subscribing services.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Not anymore (Actually since 7.1 it's not lost when PUB is down), review this:
High Availability for Extension Mobility
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/cmapps.html#wp1189079
java
java
java
java
Community Member
Enterprise subscription is true for both.
THAT WAS IT... You guys rock !
I deleted both services then added it back without checking off enterprise services
Community Member
last question, if em is used soley and there are no hard coded phones to users defined and they loose the publisher, should i configure the url's with their DNS respecitve names ?
is extension Mobility considered a lost feature if the publisher is out of service and users all running on subscriber?
-g
java
java
688
