CUCM 8.0 on VM
Hello
I am trying to run CUCM version 8.0 on a VMware workstation 6.5.2. The VM Boots up getting me the prompt username and password.
But I cannot connect using URL
the network interface on VMware  is configured as Bridge : Connect directly to the physical interface
Physical card has IP 192.168.1.67
using the command line interface on CUCM I can see the ip as 10.1.1.1
I test both IP but not working, url I tested
https://192.168.1.67/cucmadmin
https://192.168.1.67/ccumadmin
https://10.1.1.1/cucmadmin
https://10.1.1.1/ccumadmin
Any help
1 REPLY
Super Bronze
CUCM 8.0 on VM
'Bridge' networking does exactly that - makes your PC NIC, and the VM NIC work as if they are physically connected to the same VLAN/subnet.
What it doesn't do is any IP magic, so you have to ensure that your PC NIC and VM NIC have iP addresses that are layer-2 adjacent.
To prove this, set your PC NIC to 10.1.1.2, and then browse to 10.1.1.1.
Typically I would either:
1) Set the CUCM to be on an IP address of my home LAN, as 90% of the time this is where I use the VM
2) Set the networking to 'host only' on the VM. You will have a host-only NIC linked to this network, and can see the address of it when you look in the VMWare networking prefernces. You would need to give the VM an IP that matches this subnet. Bear in mind that host-only means just that - other hosts (IP phones on your LAN, other PCs) cannot reach the VM, but you could have a CIPC on your computer (or in a another VM on the same host-only virtual network) that could register to it.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
185
