07-30-2013 04:54 AM - edited 03-16-2019 06:37 PM
I am running cucm 8.0 on an MCS server.
I have forgotten the password, but i managed to do a password reset on the CLI and it was successful,
But I can not log on to the Admin page through the GUI with the new password.
Please help.
Peter.
Solved! Go to Solution.
07-30-2013 06:04 AM
Hi Peter,
I thought the method you used was for the OS admin (cli) and Security
password reset. And then you moved to the one I listed as the next step;
https://supportforums.cisco.com/docs/DOC-16780#_Reset_Application_password_on_CUCM_8
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
07-30-2013 05:41 AM
Hi Peter,
Just curious if you used;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cli_ref/8_0_3/cli_ref_803.html#wp42401
Cheers!
Rob
- Stones
07-30-2013 05:55 AM
Hello Rob,
I used:
username: pwrecovery
password: pwreset
Peter
07-30-2013 06:04 AM
Hi Peter,
Cheers!
Rob
- Stones
07-30-2013 06:54 AM
Thanks Rob,
It worked.
regards,
Peter
