02-06-2012 04:30 AM - edited 03-16-2019 09:25 AM
Hi am running with CUCM 8.0.3.20000-2
Hardware model : MCS7816I4
We need to upgrade to 8.6
Do we required a upgrade license .
currently am having some 2000 license will that been carried to the 8.6
And the whats the upgrade path directly to 8.6 or from other version and to a 8.6
can anybody give the upgrade process thanks..!
02-06-2012 04:41 AM
Yes, you need to get upgraded licenses whenever you go up a major (i.e. 6 to 7) or minor (e.g. 8.5 to 8.6) version.
Also see this page for hardware compatibility:
For your server, note (2) applies which suggests you may require a memory upgrade.
Principal Engineer at Logicalis UK
Please rate helpful posts...
02-06-2012 07:44 AM
You only need a new license when you change major version (6.x -> 7.x, 7.x -> 8.x)
Minor upgrades (8.0 -> 8.6) do not need any license changes.
GTG
