CUCM 8.5(1) and 8831 SIP Phone
I have a client running CUCM 8.5.1.11900-21. They have purchased some 8831 conference phones. In order to configure the phones do I need to install the Device Pack (cmterm-devicepack) or just the firmware (cmterm-8831-sip.9-3-3-5) for the 8831?
If I install the device pack; will it change the default firmware load for all other phones?
Thank you in advance for your assistance.
2 ACCEPTED SOLUTIONS
Hi Bill,Please check the
Hi Bill,
Please check the following post for the answers
https://supportforums.cisco.com/discussion/11833946/code-8831-conference-phone
Yes, installing a device pack does change the default loads for all IP phones.
Manish
It will change the default
It will change the default loads for all phones but you can take note of the old device defaults and set them back before you do the cluster reboot after installing the device pack.
Hi Bill,
Manish
96
