10-21-2014 02:11 PM - edited 03-17-2019 12:38 AM
Hello
I have CUCM 8.5.1.10000-26, and I need to install ip phone 7821, but I don't have the device to add it to Call Manager.
mi question is What is the release 8.5.1 that I have to update to get this ip phone in the devices.
and where in www.cisco.com can I found the compatibility matrix for 8.5.1 with IP Phones
thank you very much for your help
10-21-2014 02:27 PM
See here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
10-22-2014 08:41 AM
Jaime
thanks a lot
very helpful
12-01-2014 11:11 PM
you can download the device pack 8.5(1.17126) from link
refer table 2: compatible devices
http://www.cisco.com/web/software/282074299/114019/cmterm-devicepack8_5_1_17126_1_Release_Notes.pdf
regds,
aman
12-01-2014 11:54 PM
Hi Aman,
Thanks for your reply.
I have a query,
I see the download file is 1021 MB, will the following patch upload helps me to solve this?
7821/7841/7861 SIP IP Phone load signed COP file - Compatible CUCM Versions: 8.5(1)+
cmterm-78xx.10-2-1-12SR1-4.cop.sgn
Siva.
12-02-2014 12:08 AM
Hi Siva,
I doubt that you will get an option to add 78XX phone by uploading above firmware.
you can try that else upload latest device pack .After that u can upgrade to latest firmware.
regds,
aman
12-02-2014 03:56 AM
Hi Aman,
cmterm-78xx.10-2-1-12SR1-4.cop.sgn has been uploaded to cucm, but still the phone shows phone not registered.
i tried to add manually, but whats the phone type i should select ?
Please help.
Siva.
12-02-2014 04:01 AM
did u restart tftp service?
regds,
aamn
12-02-2014 04:05 AM
Yes i did.
we have pair of CUCM (publisher and subscriber), i done the installation only for cucm-pub, should i need to do this for sub too?
Cisco Tftp | Started | Activated | Tue Dec 2 17:32:57 2014 | 0 days 00:00:09 |
12-02-2014 04:14 AM
Not required as of now.
I still doubt that you need to upload DP on PUB,restart it and 78xx should regsiter.
Do the same exercise for SUB as well.
regds,
aman
12-02-2014 04:22 AM
Done for SUB, but no luck.
I could not see the phone type 7821 on device default page.
12-02-2014 04:47 AM
Hi Aman,
Can i try your first option, since this not workout.
"you can download the device pack 8.5(1.17126) from link
regds,
aman"
12-02-2014 05:52 AM
I installed this package cmterm-devicepack8.5.1.17122-1.cop.sgn, from link indicated by Jaime Valencia. (select cmterm-DP 8.5.1 April 1,2014)
after succesful installation (to install in pub and sub), I reset tftp server, but it didnt work (the device exist in device default but not register)
then I had to reset the cluster (first publisher after suscriber).
after that it works fine.
and the firmware is sip78xx.10-1-1SR1-4
regards
12-02-2014 05:56 AM
When you are adding support for a new device , the cluster needs a reboot after installing the file. For firmware upgrade scenarios a restart of TFTP is sufficient.
Manish
12-02-2014 04:49 AM
