CUCM 8.5.1 ip phone 7800
Hello
        I have CUCM 8.5.1.10000-26, and I need to install ip phone 7821, but I don't have the device to add it to Call Manager.
        mi question is What is the release 8.5.1 that I have to update to get this ip phone in the devices.
        and where in www.cisco.com can I found the compatibility matrix for 8.5.1 with IP Phones
     thank you very much for your help
Everyone's tags (1)
See herehttp://www.cisco.com
See here
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
java
if this helps, please rate
www.cisco.com/go/pdi
 Jaime         thanks a lot
Jaime
         thanks a lot
         very helpful
VIP Purple
Hi,you can download the
Hi Aman,Thanks for your reply
Hi Aman,
Thanks for your reply.
I have a query,
I see the download file is 1021 MB, will the following patch upload helps me to solve this?
7821/7841/7861 SIP IP Phone load signed COP file - Compatible CUCM Versions: 8.5(1)+
cmterm-78xx.10-2-1-12SR1-4.cop.sgn
Siva.
VIP Purple
Hi Siva,I doubt that you will
Hi Siva,
I doubt that you will get an option to add 78XX phone by uploading above firmware.
you can try that else upload latest device pack .After that u can upgrade to latest firmware.
regds,
aman
Hi Aman,cmterm-78xx.10-2-1
Hi Aman,
cmterm-78xx.10-2-1-12SR1-4.cop.sgn has been uploaded to cucm, but still the phone shows phone not registered.
i tried to add manually, but whats the phone type i should select ?
Please help.
Siva.
VIP Purple
did u restart tftp service
did u restart tftp service?
regds,
aamn
Yes i did.we have pair of
Yes i did.
we have pair of CUCM (publisher and subscriber), i done the installation only for cucm-pub, should i need to do this for sub too?
Cisco TftpStartedActivatedTue Dec 2 17:32:57 20140 days 00:00:09
VIP Purple
Not required as of now. I
I still doubt that you need to upload DP on PUB,restart it and 78xx should regsiter.
Do the same exercise for SUB as well.
regds,
aman
Done for SUB, but no luck.I
I could not see the phone type 7821 on device default page.
Hi Aman,Can i try your first
Hi Aman,
Can i try your first option, since this not workout.
"you can download the device pack 8.5(1.17126) from link
https://software.cisco.com/download/release.html?i=!y&mdfid=283423434&softwareid=282074299&release=8.5(1.17122)&os=
refer table 2: compatible devices
http://www.cisco.com/web/software/282074299/114019/cmterm-devicepack8_5_1_17126_1_Release_Notes.pdf
regds,
aman"
Hi    I installed this
   I installed this package cmterm-devicepack8.5.1.17122-1.cop.sgn, from link indicated by  Jaime Valencia. (select cmterm-DP 8.5.1  April 1,2014)
after succesful installation (to install in pub and sub), I reset tftp server, but it didnt work (the device exist in device default but not register)
then I had to reset the cluster (first publisher after suscriber).
after that it works fine.
and the firmware is sip78xx.10-1-1SR1-4
regards
When you are adding support
When you are adding support for a new device , the cluster needs a reboot after installing the file. For firmware upgrade scenarios a restart of TFTP is sufficient.
Manish
VIP Purple
upload dp in both servers and
upload dp in both servers and restart them
Hi Aman,I have uploaded the
Hi Aman,
I have uploaded the file cmterm-devicepack8.5.1.17122-1.cop.sgn (1021 MB) on both Pub/SUB and rebooted, now the 78xx phones are registered withour any issue.
Thanks for your support
Siva.
VIP Purple
thanks for update. regds,aman
thanks for update.
regds,
aman
Hi Jaime, We have CUCM :
Hi Jaime,
We have CUCM : System version: 8.5.1.10000-26 and new 7821 ip phones to be added :sip78xx.10-1-1SR1-4
Could you please suggest me which devpack i should download for this compatibility.
Attached is the snap of the same.
Thanks in advance.
Siva.
232
